donn0128
Nov 12, 2014Explorer II
Cant do it unless you also remove the holding tank and then replumb the waste system. Better solution might be to learn the proper use of an RV waste holding system and dump once a week or so. BTW RV's do NOT have a septic system. They do have waste holding tanks. Proper use generally does not result in odors improper use does.
About RV Newbies
