K_Charles
Nov 12, 2014Explorer
on our TT you flip a switch when the tank is full and then after about a min you flip the switch back. It takes about a second to flip the switch and we do it about every 5 days. If you are parked in one spot you don't need to play with the hose only open the valve. The easiest way would be to learn how to use what you have.
About RV Newbies
