Skibane
Dec 10, 2021Explorer II
Bobbo wrote:
Plugged in. BUT, I replaced the OEM converter/charger with one that will take care of the batteries rather than boil them dry.
Simple Test: Measure your house battery voltage with the converter/charger turned on, after it has been running for a few days.
If you measure something in the 13.2 - 13.8 volt DC range, your converter is doing a decent job of maintaining the batteries. If the voltage is much higher than that, you're probably going to need to add water frequently.
About RV Newbies
