Mickeyfan0805
Mar 07, 2018Explorer
I don't have any experience with the Wildwoods, so will leave that to others (the advice to check out the manufacturer forum is probably most beneficial).
I also don't have experience with the murphy bed, but I would echo the advice to be very considerate about the need to set up and break down every night. I've not seen it, so I don't know how easy it is. If it truly is as simple as 'pull it down and climb in,' that probably wouldn't bug me. If you have to move cushions, lower tables, shift things around, re-make beds, etc...however, that could get very tiresome very quickly. A requirement for us was that we needed enough static beds for everyone. It eats up trailer space, but makes it a much more pleasant experience in the evening.
All of this is balanced by your size and budget requirements too, but it is something to keep in mind!
About RV Newbies
