pitch's avatar
pitch
Explorer II
Nov 03, 2013
Power to RV
My hybrid has never been without power. I keep it plugged in on a 20A circuit 365 days a year. I was told yesterday by a motorhome owner that it was not good to do it, although he did not give me any reason other than his dealer told him so and that he never plugs his coach in.
I use mine as a respite from the house at times and I like convenience.
Am I doing any harm?
  • If you're worried about it then pull the negative battery lead or install a disconnect switch.
    Modern converters with "smart" charging can be left plugged in continuously. Older ones (Magnetek & Elixir come to mind) were "dumb" single stage converters and could boil the batteries.
  • pitch,
    If you have a good three (or four) stage battery charger (often called a "converter") that is maintaining the batteries, there should be no harm. If you have one of the cheap pieces of junk converters that come with so many RV's, then you will likely boil your batteries. At a minimum, I suggest you check the battery water frequently until you determine how quickly it is going down.
    I agree, it nice to have a little place to go and relax....and pretend to be camping :)
  • Nothing to worry about, think about the full timers, they are always plugged in. I have been doing it since day one.
