lanerd
Mar 31, 2015Explorer II
Grandpere wrote:Old-Biscuit wrote:
Camping season.......fill toilet bowl full and flush (2 times) after dumping/rinsing black tank. This keeps tank bottom wet so any poop doesn't dry out. Dried poop turns hard as concrete. Also with 2 toilet bowls in tank it is ready for use.
Winter/storage season.......drain/rinse tank thoroughly and then add some RV anti-freeze to keep tank bottom and dump valve seals wet. Water OK but anti-freeze eliminates freeze concerns
Tank additives....
Personally don't use them. Can't stand that 'chemical smell'.
When tank vents, seals, 'p' traps, AAVs work there is no smell inside rv except for that moment of flushing toilet, which tank chemicals does nothing for.
Use them if you want...it's your rv.
Has no effect on me
X2 except for the additives. We have used Thetford which does a great job on the smell. However this season we are going to try Walex BIO-11530 Bio-Pak Natural Holding Tank Deodorizer and Waste Digester. I am hoping this product will help with breaking up the toilet paper and also the solids plus handle the smell.
Also, when we dump we rinse the tank at least twice using the Camco Swivel Stik Rv Tank Rinser.
If your toilet does not go straight into the black tank there is a flexible version Camco 40074 Flexible Swivel Stik
Russ, with all due respect, if you have an odor that requires you to dump in chemicals to mask....you have a problem. Typically, the most common reason for black tank odors in the interior of an rv is due to a malfunctioned Air Admittance Valve (AAV) that is located under a sink (kit or bath or both). Locate, remove, and replace this valve and I bet your odors will disappear. There can be other reasons for interior black tank odor (clogged vent, poor seals, etc), but the AAV is typically the culprit.
Adding chemicals to your tank is just throwing your $$ down the toilet. Find the problem and fix it.
Good luck with this..
For the OP (mtnbbud), I too will add a couple of gallons of water back into my black tank immediately upon draining and flushing it. As mentioned, keeps the solids for solidifing. As for your sensors... what I do before each day of traveling, is after draining and refilling and draining again until nothing but clear water comes out; I will add a few gallons and also a cup of laundry detergent (I use Oxy Clean). When traveling, the back and forth movement of the rv will slosh around the soapy water and will "sometimes" clear the sensors of what may be clinging to them. Give it a shot and see if it helps.
Ron
About RV Newbies
