Grit dog wrote:
After reading dlpllg's post, has anyone found a soap/ foam Cannon whatever that truly softens "normal" dirt and road grime enough that a normal 2500 psi pressure washer actually gets the vehicle 100% clean with no touch, no scrubbing?
I'd pay for that, just haven't found one yet I believe will work 100%.
Neighbor even bought the expensive chemical guys setup and foam a couple years ago. Said how good it was initially and then reality set back in and it doesn't actually do the job 100%. Back to rags, sponges and brushes...
DPG here,
I tried foaming and letting it sit and then using the pressure washer to rinse with the appropriate nozzle and it didn't get it totally clean. Using the brush really made a difference. It wasn't that hard just kept moving the brush. No need to keep dipping it into the soap bucket as soap was already one RV. The trick is to let it sit and soften as much of the dirt as possible.
Dave
