Chuck_thehammer
Aug 27, 2016Explorer
winterizing is a must IF going below 30 degrees .. longer then 12 hours.
I do the air pressure WAY,, 30 psi and open each valve one at a time till NO water exits. then the next valve/fixture...
if you have outside shower.. do it as well.. HOT and COLD sides. empty all tanks..
and place the RV antifreeze in Drains, and Commode
a Dry camper is a happy Owner. replacing plastic hoses and fitting are not as easy at it sounds..
About RV Newbies
