Oaklevel
Sep 07, 2016Explorer
When you go into a used trailer if if smells musty stay away probably has or had a roof or other leaks. Roofs and window areas are prone to leak check those areas closely. If paneling in soft or flooring stay away.........
The DW would put new flooring in a new camper if the original was carpet. :) so new flooring is not necessarily a big deal.
Make sure everything works.....
About RV Newbies
