slider45
Oct 21, 2020Nomad
SAR Tracker wrote:
Fresh water: get a model that has a fresh water dump valve. Or install one. Otherwise, you have to empty thru the sink, into a gray tank, then out the pooper pipe.
Gas tank / station: Ensure your gas station / generator fuel pickup is near the bottom of the tank. Otherwise, one or the other will run out.
Definitely prefer one with fresh water. A neighbor had a some hard time with water access on their last TH.
About RV Newbies
