superrayzor's avatar
superrayzor
Propane low pressure?
I am trying to cook on my stove, i've never really used a propane stove before.
The pan gets hot, but I have trouble browning ground beef that is broken up for taco meat, the pan cools down and won't get hot enough again.
Am I missing something for turning up the pressure or flow so it can get hotter? Or is this just the life that I get to have with the RV?
  • Mandalay Parr wrote:
    Mine gets as hot as a regulat stove.
    Mine absolutely does not. I am even using a Le Creuset cast iron pan which should retain a lot of the heat. Once I put the ground meat in, the pan cools down and I almost get 'boiled' ground beef.
    Just now I tried letting the pan get to smoking where the windows are all open and I am worried the smoke alarm is going to go off. I added the meat - slowly so the pan doesn't lose heat rapidly. Stirred it, broke it up, added a little more. By the time I added all of it, the pan was cooled down quite a bit, and again is not browning the meat and does not get back to sizzling.
    I've done this meal 100 times on my NG stove at home and never had an issue. Even did it on an electric stove a few weeks ago with no problem.
