theoldwizard1
May 20, 2018Explorer II
Depending on your plumbing, you may or may NOT have a automatic valve that switches tanks when one get low. Some propane refill stations charge a flat rate to fill a tank, regardless of how full or empty it is (maybe more true for 20 lb tanks). Only remove the "empty" tank.
If you do NOT have an automatic valve, never open both valves at the same time. If one is empty and one is full, you will quickly have TWO half full tanks.
Some propane stores may fill them while they are still mounted on the trailer, but you will likely have to disconnect/connect the hose(s) yourself.
About RV Newbies
