JaxDad
Apr 14, 2018Explorer III
Johno02 wrote:
It is not recommended to use ropane tanks for air. According to what I have heard, compressed air usually has a good amount of water in it, and propane tanks are not sealed inside. Again, according to what I have been tolde, continued use of air will cause moisture inside and rust, leading to failure, which could be very bad, depending on the instance. So not my opinion, just what I have been told, but I wouldn't do it.
The simple solution for that is to invert the tank and drain it after use, the water settles into the opening and is the first thing out with a head of air behind it.
About RV Newbies
