- naturistNomad IIBack in the day we used to use old propane tanks for compressed air at 100-125 psi for tire reinflation after being on the beach or for extra air when running the sports car in autocrosses and hillclimbs. Did it for years. If you put a water separator on the compressor, shouldn't be a problem with internal rust for many years.
- Johno02ExplorerFrom the web:
More on propane tank conversion...
by: Anonymous
A propane tank has to be made to withstand over 140 psi as propane becomes a liquid at 140 psi (at room temperature), any container with a mix of liquid and gaseous propane will be pressurized to 140 psi, regardless of the ratio of liquid to gas. The major problem associated with using a propane tank as an air tank is that the tanks is just welded steel so one should coat the inside of the tank with a rust preventative paint and the tank new plumbing should allow for the draining of water from the tank. ie the tank should be upside down with a drain valve at the lowest level. Removing the old propane valve is the most difficult part of the conversion. After removing the valve por in the rust preventative paint put the valve back on temporarily and roll the tank and turn it end over end several times so the whole insides of the tank gets coated with paint. Remove valve, drain out excess paint and let the tank dry for several days before adding new pipes and valves. Include a pressure relief valve.
___________________
The writer, who chooses to remain anonymous, but did actually sign in as DUH (unfortunate name that) makes some valid points.
Good that a propane tank is built to withstand 140 PSI. But... what is it rated for in terms of higher pressure. That you need to find out as your typical DIY type air compressor will discharge 150 PSI, and some of the more industrial types will send 200+ PSI into the tank.
If the propane tank is rated with a burst pressure exceeding twice the maximum pressure the compressor would put into it, then sure, use it, along with the PRV set to blow off way below the burst pressure of the tank, as the writer suggests. The thing is, if you don't know the burst pressure of the tank, don't use it! At least as far as I'm concerned. - Johno02ExplorerIt is not recommended to use ropane tanks for air. According to what I have heard, compressed air usually has a good amount of water in it, and propane tanks are not sealed inside. Again, according to what I have been tolde, continued use of air will cause moisture inside and rust, leading to failure, which could be very bad, depending on the instance. So not my opinion, just what I have been told, but I wouldn't do it.
- BB_TXNomad100 psi should be no problem. Propane in a tank can go well over 200 psi when hot. Good chart below. Plus lots of other good info.
Propane pressure - Old-BiscuitExplorer IIITypically 100 psi to 250 psi ---normal range
Colder temps....lower pressure
Hotter temps....higher pressure
Relief Valve ....300-315 psi - path1ExplorerOp here...
Thanks... I tried googling up transfer pumps for propane, ect...with no luck.
Thinking about using 2 old tanks for air tanks, looks like 100 psi I should be OK - theoldwizard1Explorer IILiquid propane is cold, but it warms up as it is added to the tank. The same amount of propane, in the same tank can have a wide range of pressure depending on its temperature.
- SoundGuyExplorer
path1 wrote:
When re-filling a propane tank...what is the PSI? Anybody know?
I don't but Google does. :W
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
