Big_Katuna
Feb 21, 2017Explorer II
Its called gravity. When you flush a toilet, gravity pulls the water into the bowl then down through the trap into the pipes where it flows downhill. Water will not flow uphill.
I push the hose up under the exit hole. Its not that messy assuming you have a black tank rinser and or flush with gray water.
About RV Newbies
