Rice
Feb 22, 2017Explorer III
Big Katuna wrote:
I push the hose up under the exit hole. Its not that messy assuming you have a black tank rinser and or flush with gray water.
I was thinking about pushing the hose farther than just into the bowl. If you push the hose down farther, does that mean the black water bypasses the clean water in the bowl, or does it still get up there but maybe isn't as concentrated?
I have a Sewer Solution and now that I know how the macerator works in a toilet, I'm thinking the Sewer Solution could also be used in a toilet. Plus, I could test it with fresh water before making the black water (or even gray water) commitment.
Thanks for the photo, aridon--that really helps.
About RV Newbies
