hmknightnc wrote:
Old-Biscuit wrote:
Buy a spare battery, keep it on a battery tender and then just install when you rent the Ailiner.
Easy---peasy 12V DC power for LP operation.
Unless fridge can be run on 12V (3 way fridge....AC, LP, DC) you will only be able to run fridge on LP while enroute.
x2. Plus if the rentals have a 7-pin plug it is very likely just connecting to the tow vehicle will energize the pupups 12 volt system allowing you to run the fridge on propane. (check to make sure the pop up doesn't have a battery disconnect switch, if it does then you probably need to have it on for this to work)
I was wondering if this was the case, I wasn't sure since my tow vehicle was wired with a 4-pin plug when I had a hitch installed. I figured using the 4 pin to 6 or 7 pin adapter would mean those extra pins could not be used, and I know one of those extra pins is the 12vdc power. If that pin still receives power despite my vehicle only having a 4 pin connector that would be great.
