Salty_Dog
Dec 22, 2013Explorer
We have camped in weather below 10F. Fill your fresh water tank and use that as your water supply. Take your fresh water hose out to refill the tank as needed and then bring back inside. Connect your sewer when you dump and then disconnect when finished and stow away. Run your furnace as primary heat when below 32F to protect your pipes and tanks from freezing. When outside temp is above 32, use which ever your want. Keep an eye on your propane tank level - you don't want to run out at 2 in the morning. Last thing - enjoy your time there! Winter camping can be a blast!
About RV Newbies
