bsinmich
Dec 30, 2013Explorer
You probably have around 80+ gal of fresh water capability. If you are using only the heat pumps you can turn on the blower switch on the water panel that will help keep the tanks from freezing. The heat pumps won't do much below 40F so you will need the propane. Your Newmar is better equipped for cold weather than 90% of the other coaches out there.
About RV Newbies
