Robin1953
Jun 04, 2014Explorer
Wavesprite wrote:My best guess is that the quick connect on your trailer is plumbed after the trailer regulator. Since your stove is a high pressure unit you will probably need to remove the stove regulator to use the quick connect. You could run a hose from a tank as you stated.
First of all, I am sorry in advance because I KNOW this has probably been discussed here so many times.
I have a Camp Chef Everest (High pressure) stove that I want to try to use with my quick connect port on the side of my RV. Is it even possible, and if so, could someone give me the simple, easy to follow steps to do it?
Also, another question is, we have dual propane tanks on the camper, I can always just disconnect one of them and run a hose with no regulator directly to the stove, correct?
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
