RoyB
Feb 17, 2015Explorer III
This is a typical 30AMP Wiring configuration on what runs what in a 30AMP RV system setup.
Not sure what you are asking concerning an INVERTER. The Inverter is an optional item usually added by the user which runs from your batteries and provides 120VAC to run a few 120VAC Appliance items when NOT connected to the Shore Power pedestal or Generator.
Using an INVERTER requires a larger battery bank as it takes alot of DC CURRENT from the batteries to operate.
Study the block diagram to refresh yourself on what things are called in the modern RV's.
Roy Ken
Roy Ken
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
