2oldman
Oct 12, 2017Explorer II
Re: Battery Advice Needed & Charging Questions
brianosaur wrote:2x6v would be the minimum for boondocking. Most of us have inverters which can demand a lot from batteries.
Would one only go with 2x6v's if they constantly boondock?I assume the easiest way to charge the battery is to make sure the gene has an identical 30a outlet that will receive my TT power cord?
Unsure of what size gene to get also. Any advice would be appreciated.
No, you don't need a 30a socket. Adapters are fine.
For your light use I'd suggest a 1000w Honda. Very quiet, very dependable.
