leftysExplorerJan 23, 2015Battery LifeMany posts advice you to use the battery disconnect switch to avoid battery drain while in storage. My question is, if my motorhome storage facility has power available does it make sense to keep the ...Show More
leftysExplorerJan 26, 2015After checking the RV, I found the "Inverter/Charger" (Magnum Energy, model MS 2000).I could not find a separate "Converter". Does that mean that my "Inverter/Charger" functions also as a Converter?And, to answer the last question, I don't expect the motorhome to be in storage more than 6 weeks at a time, or so.Thanks for the help!
Related ContentBattery LifeBattery Life?House battery lifeHouse battery drainBattery life, fridge only
