eaugustin wrote:
I am new to RVing, purchased a 2013 Thor Class C. After my RV had set for approx. a month this past winter, I was preparing for a trip and when I tried to start the motor both batteries were dead and I had to have a battery service out to jump both batteries. I drove the RV to my service center to test the batteries, and was told that the generator must be started and run for 2 hours every 2 weeks. Can someone verify this?
I have a battery disconnect....but after finding my batteries drawn down each time I returned I decided to remove the neg wire off the house batteries......viola....problem solved
You do not need to run you generator as said.....but when you do use the MH make it a point to run it under load for awhile....generators need to be exercised....
