4x4van
May 26, 2020Explorer III
sailmike1 wrote:Depends on the unit. If the unit you purchase has only one wire for powering the camera/monitor, you use a wire that is hot when the ignition is turned on instead of the backup light wire.4x4van wrote:
No switch is needed; simply power it off of a wire that is hot with the ignition rather than from the backup lights.
Mine comes on in reverse, but has a manual switch on the monitor that turns it on constantly. That's how I use it.
How would I connect it to that wire?
Thanks!
About RV Newbies
