DrewE
Feb 26, 2016Explorer III
If you have a CVT (automatic) Fit, you must use a dolly. It cannot be towed four down. The earlier (2013 and older) automatic Fits had a different transmission, not a CVT, that could be towed four down, but the current generation can not be towed that way.
If you have a manual transmission, it most likely can be towed four down; double-check in the owner's manual under recreational towing. Most people seem to agree that towing four down is more convenient. It may cost a bit more to get set up initially and it definitely is less readily adaptable to other vehicles, but you do have a lot less extra equipment to worry about and hooking up and unhooking is less involved.
If you do tow with a dolly, consider getting an aftermarket hitch for the Fit so you can use it to tote the dolly around if you need to move it from the campsite.
About RV Newbies
