wildtoad
Feb 26, 2016Explorer II
I hope you checked to see if your new car can be towed 4 down before purchase otherwise you will be limited to a dolly. Dolly's are good if you want the opportunity to tow different cars without having to modify the car. The main drawback to Dolly's is its one more thing to keep track of, and deal with at the campsite. Some don't find this to be a problem. Towing four down entails a lot of towed car setup, auxiliary braking systems, and alterations to the car. Some setups more than others. But after you do that the daily activities regarding towing are simpler. Keep mind when you change cars you will go through the setup again.
About RV Newbies
