2oldman
Sep 30, 2013Explorer II
westernaccents wrote:Yes. You can actually use both.. the one with the highest pressure wins. No, but if you mean the exterior hose, you don't want that freezing.
Is it prudent to also have the fresh water side full (inside tank)?? I am assuming that I can use The "city side" for pressure, then if needed , just turn my water pump on to use my Holding tank?? If this is acceptable, do I need to disconnect the "city side" 1st??
I am also concerned of contaminating my tanks after reading some "disinfecting" threads here..
It's your call. I've seen many 'non-potable' water sources which are just fine, it's just that the local water board doesn't treat it so it can't legally be called "safe". It may be just fine.
About RV Newbies
