westernaccents's avatar
Sep 30, 2013
Recommendations on this "water use" scenario
Yes I am a total newb, about to make a maiden voyage in my new to me 3010tt Cyclone.
Scenario: Place I'm going to, has a spring fed, NON-potable water source (gravity pressure to main faucet head). I have seen many a camper here using this water as a "city source" over the years.
I was considering doing the same thing and am concerned about low outside temps causing freezing. Is it prudent to also have the fresh water side full (inside tank)?? I am assuming that I can use The "city side" for pressure, then if needed , just turn my water pump on to use my Holding tank?? If this is acceptable, do I need to disconnect the "city side" 1st??
I am also concerned of contaminating my tanks after reading some "disinfecting" threads here..
Any tips please?
  • If my tank is 20 or so gallons, that is not much weight for the convenience. Now I just have to learn how to camp in the cold, especially throughout the day when I'm not in the TT. Think I will get a "buddie" heater and run it on low when I'm outside.
  • bukhrn's avatar
    bukhrn
    Explorer III
    If your RV has a filter after the fresh water tank, I'd use the spring water, you can also add an inline filter before it comes into your tank, but I agree with 2oldman "It's your call. I've seen many 'non-potable' water sources which are just fine, it's just that the local water board doesn't treat it so it can't legally be called "safe". It may be just fine."
    I too have drank (or drunk), water from many springs in my time nothing wrong with them, in several cases actually tested cleaner than some city water supplies,they simply were not over loaded with chlorine like most city systems, which actually tastes nasty.
  • bukhrn wrote:
    If your RV has a filter after the fresh water tank, I'd use the spring water, you can also add an inline filter before it comes into your tank, but I agree with 2oldman "It's your call. .
    I would think that it would depend greatly on exactly what kind of a filter is installed. but why "cruddy" up your FWT with unsafe water in the first place?
    bumpy
