BB_TX
Feb 28, 2014Nomad
pchartrand wrote:
Mine is in auto, but it's in error mode and off when I arrive.
Pat
Do you open your propane tank valve? In auto, when you lose 120 VAC it will switch to 12 VDC and propane. If propane is not available it will give a check or error light.
Sounds like either you did not open the propane valve, or you did not open a range top burner valve and momentarily light a burner to get propane thru the gas lines close to the fridge.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
