Executive45
May 12, 2020Explorer III
Smog checks are the biggest PITA to registering a vehicle in California. It's also the one of the most abused systems. That said, California law requires ANY gas powered vehicle built AFTER 1975 to pass the smog test. IMO, the smog station will see a 1977 vehicle as a money maker for them. Expect it not to pass on the first try. So, now a few questions. First, where is the vehicle currently? It sounds like it's in Ca but with Az plates, correct? If that's the case, a smog check will still be required to register it in Ca. The 30 yr rolling exemption went away years ago. You'll also have to present the vehicle to a DMV employee for a VIN check. Know where your VIN is located for your convenience. Otherwise expect the DMV person to spend time looking for it. Your county will determine your USE TAX, which is simply a SALES TAX under a different name. Whatever your county's sales tax is will be what you'll have to pay. If the vehicle is currently in California, I'd ask the seller to get it smogged prior to purchase. That certificate is good for 90 days. Take that cert to the DMV along with a fist full of cash and you'll be good to go.....Dennis
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
