- Grit_dogTrailblazer
BB_TX wrote:
Just to add. The eraser wheel works great on fiberglass. But may take off paint on an aluminum sided trailer. You don't say what you have.
Eraser wheels are great for leftover goo after removing trim pieces and old crusty decals that won't pull off after heated. But a lot of decals will pull off pretty easy with some heat froma heat gun and skills with a razor blade.
Don't use on aluminum or powder coat and for some reason it burns pretty easy on my camper fiberglass. Gave up on the wheel and started scraping and peeling. Didn't take too long. Clean up the residue with lacquer thinner....again except on powder coat. - dpgllgExplorerI removed the decals on my front cap, rear, and just the Flagstaff logos from each side of my 5th wheel. I used this adhesive remover:
Aircraft Decal and Adhesive Remover
It did a really good job for me. I STRONGLY ADVISE you to test in a small area first just to make sure that it is safe for your finish.
Dave - BB_TXNomadJust to add. The eraser wheel works great on fiberglass. But may take off paint on an aluminum sided trailer. You don't say what you have.
- DBabylonExplorerthese are all great suggestions. I will try them once I pick up the trailer.
- BB_TXNomad3M eraser wheel and a good corded drill. Will take off the decal and most of the adhesive. Then use 3M adhesive remover, or mineral spirits, to remove the remaining adhesive.
- snowpekeExplorerI used a rubber wheel that I put on my drill, got it at a paint store. Worked well with no damage.
- towheadExplorerwarming it up with a hair dryer really helps to peel it off.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
