when traveling is it more costly to run dash air or run roof ac with generator. Will make first trip friday in 40ft. mh. will dash air keep mh cool enough.
When the outside temperature is not very hot the dash ac will be fine. But when it is boiling outside you will want to run both and you won't care if it is more expensive. You can also factor in what it will take to cool the coach down when you stop for the night. It will cool down a lot faster if it is cool already.
And on edit, why did you post twice? Now you have ruined my day.
