enblethen
Jul 27, 2014Nomad
Suggest you add your rig to signature so those having same or similar make and model can chime in.
Cable connection could be going through the antenna power supply. Satellite connections must go straight from sat dish to receiver.
You may check your documents to see if the rig came with a sat connection on exterior.
About RV Newbies
