If the jenny is in the bed of your truck, how do you use your truck yet run the genny to run the A/C or charge the batteries?
ROBERTSUNRUS wrote:
:) Hi, I used four "D" rings mounted to my truck's bed The two larger "D" rings are mounted with two of my bed bolts. The two smaller "D" rings are mounted to my bed with bolts; I had to drill two holes. I use a coated cable and two large locks to the large "D" rings and a ratchet strap to the smaller "D" rings. I have a Yamaha 2400 and I made a turned up exhaust extension and wrapped it with heat wrap. When not in use, my roll top bed cover hides it.
