I finally got around to take the TV and TT to level ground to work on getting my WD hitch setup correctly.
I set the ball height of the hitch to be about 1/2" higher than the top of the ball cup on the TT as I've read in different manuals. I had to flip the square shank to be up facing instead of down, that seems to be okay as I've read.
HOWEVER, even after adding a few washers to cause the tilt of the hitch back towards to the TT, I can't get the back end to not drop less than 2.5 inches. The front is raising about 1/2" still as well.
I ran out of links, even trying seven but I know that it's not correct because it causes the WD bars to be not level with the TT tongue.
What am I missing? Do I need to raise the ball height on the shank more? Do I need to go purchase more washers to increase the tilt?
Thanks again in advance for the forum members assistance.
