the_bear_II
Mar 19, 2014Explorer
CarpFishermanAndWife wrote:
Please verify these steps are correct (this is Wife asking making sure hubby does it right - LOL):
1. Unhook the sway arms before backing into site. (Is this completely necessary if you are just backing straight in to a paved, level spot?)>>> only need to do if tight turns to get into site
2. When trailer is where you want it, leave connected to truck and put chocks around wheels. (Do you also use the chocks you drive on to level it?)>>>>>> Make sure electrical cord, water hose and sewer hose will reach campground pedestal/ sewer connection and water outlet. Drive up on blocks to level and then chock wheels
3. At this point, do you unhook the truck or put down the jacks? >>>> I unhook at this point.
4. We also have X-chocks that go between the front and back wheels. Do these go on after the truck is disconnected? >>>> before truck is disconnected
5. Anything else we need to know about setting up and disconnecting? >>> put down stabilizers/jacks all four corners or jackstands.
Thanks!
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
