GaryWT
Mar 19, 2014Explorer
I have an equalizer hitch combined sway and weight so I don't remove anything, double check on this for your type. Not all sites are level so check level side to side, drive onto boards or lynx levelers as needed to level. Next put you chocks against the wheels. Once done unhook so you can level front to back. Once level the corner jacks can go down. X chocks can go at this point I believe. I always hook up water, electric, sewer and cable before opening slides so they are not in the way. Be sure that you parked so the slides do not open onto your neighbors site. Good luck and have fun.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
