Tom_Diane
Mar 19, 2014Explorer
All good advice. A TIP: If you are in a cg with gravel roads/pads, and you are on a slight grade to back into a tight spot, I have removed the sway control always before backing. In the case of a grade, I removed the weight distribution before backing into a site also to give more traction.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
