Tom_Diane
Mar 20, 2014Explorer
1971duster340 wrote:Beside giving more traction, I remove the sway bars AND the WD before backing into a site for the reason given above if the site is uneven.ah64id wrote:
Others have chimed in with great responses, but I will throw my routine in for campground parking.
7) Use tongue jack to take tension off of of equalizer bars, and remove bars.
This wasn't mentioned in some posts, but Yes this is important and will make the tension chains much easier and safer to remove and install. There are hundreds of lbs. on the cheater pipe that releases the chains if you don't use the tongue jack. Even more weight if you aren't straight.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
