HappyKayakers
Nov 14, 2013Explorer III
2012Coleman wrote:
That's a lot of missing stuff! I'm seeing reg flags here - why is the toilet and holding tank missing? Does everything else work - A/C, furnace, hot water heater, stove, refridgerator to name a few. Don't take this persons word that they do. Is the Gray water tank there? Are the dump valve and plumbing present underneath it? I'd be skeptical of buying an RV that is missing a holding tank and toilet.
X2. I would also be concerned about the flooring in the commode room. You should also check with the proposed RV park and ask about age limitations on RVs. Sounds like you're on a limited budget and this RV may exceed their age rules.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
