armandxp
Nov 14, 2013Explorer
HappyKayakers wrote:2012Coleman wrote:
That's a lot of missing stuff! I'm seeing reg flags here - why is the toilet and holding tank missing? Does everything else work - A/C, furnace, hot water heater, stove, refridgerator to name a few. Don't take this persons word that they do. Is the Gray water tank there? Are the dump valve and plumbing present underneath it? I'd be skeptical of buying an RV that is missing a holding tank and toilet.
X2. I would also be concerned about the flooring in the commode room. You should also check with the proposed RV park and ask about age limitations on RVs. Sounds like you're on a limited budget and this RV may exceed their age rules.
I will check that, thanks. Def. on a budget. Needing to move into something cheap in the Orlando area so I can go to college, and found a lot rent for $300 and they didn't seem real picky. Going to check out the lot this weekend to make sure.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
