Second_Chance
Feb 02, 2018Explorer II
A 3/4-ton truck will not handle "most" fifth wheels. A crew cab diesel with 4WD has an even lower payload rating than a 2WD gasser because of the extra weight in the drive train. With a fifth wheel, it's about payload and not towing capacity. Figure out what you have left for rear axle capacity on the truck (loaded, people, hitch, etc.). Multiply that by four and you'll have the GVWR for a fifth wheel you can comfortably handle.
In my opinion, fifth wheels handle better - especially in high winds. A 33' fifth wheel should actually end up shorter overall than a 28' TT because of the lack of the A-frame on the front (as on a TT) and because a good part of the fifth wheel overhangs the truck.
You don't necessarily need a slider with a 6.5' bed. It depends largely on the pin box placement and the front cap design of the fifth wheel. We pulled our first 12K miles with a 6.5' bed without a slider and did just fine (we used an Andersen Ultimate). Sliders can be extremely heavy and you may not want to give up the extra payload. At less than 50 lbs., the Andersen is a good alternative to consider for a 3/4-ton truck.
Rob
Rob
About RV Newbies
