drsteve
Feb 02, 2018Explorer
JEB17245 wrote:
We plan on buying a RV soon and are struggling with choices. We have a 2014 F-250 6.7 diesel so we can handle most RVs, but would like suggestions for either a bumper pull or 5th wheel. The truck bed is the 6.5 short bed. If we go with a 5th wheel I understand that we need a hitch with a slider and is it important to have one that pivots side to side and front to back to improve the tow?
We're also struggling with length. What is the difference in towing a 28' versus a 33'? I know 5':). Does a 5th wheel make towing a longer trailer easier?
Thanks in advance,
John
A fifth wheel is easy to pull because they don't sway, and the hitch requires no setup. A properly set up bumper pull also tows just fine. You'll find many different opinions on which is better.
With a bumper pull, you still have use of the truck bed for storage. 5ers usually have more inside storage area than a TT. A 5er has steps to the front area, an issue for some with mobility limitations. 5ers tend to be heavier. TTs are usually cheaper. 5ers are taller, so watch for low hanging trees.
A longer unit is most noticeable when making gas stops, parking, and backing. A fifth wheel makes for a shorter overall length, since some is over the truck bed. With either, five feet isn't much difference. A shorter rig gives you more campsite options. Older campgrounds with narrow roads and other obstructions may be difficult for 30+ foot units.
About RV Newbies
