- tatestExplorer IIWhat dows "severe thunderstorms" mean where you are located.
Here, I lower than antenna and pull in the slideouts, because it can mean straight winds exceeding gale force, and gusts over 80 MPH. That is enough to bend an extended antenna, get under slideouts and awnings, and tumble some lighter RVs. To say nothing to having trees fall on you, been through that too.
Generally if severe thunderstorms are forecast for someplace, I will try to be someplace else, if I am in my RV. I've cancelled some campouts on forecast. Last may, tornadoes ripped through the park we would have been in, and I was happy that I had cancelled.
Other places in the country, forecasters might call lesser storms severe; here on the plains it means hunker down in the storm shelter. - old_guyExplorerheck the lightning hits the antenna, it is going to go through that tv set like gang busters whether it's up or down.
- handye9Explorer III would lower then antenna, if winds were high. I'd be more concerned about wind damage, than lightning strikes.
- ScottGNomadI absolutely would.
- Winnebago_BobExplorer
BB_TX wrote:
If the lightning can travel thousands of feet from the clouds to the ground, it is not going to care whether your antenna is up or down.
I don't think the lightning would be the concern - generally T-Storms (and we lived in Corpus for 7 years) have a wind component that would be the bigger concern. - LilrhodyExplorerNot worried about lightning - lots of things much taller than us where we are tonight - plus we are sitting on rubber tires.
More wondering about the wind potential. N - BB_TXNomadIf the lightning can travel thousands of feet from the clouds to the ground, it is not going to care whether your antenna is up or down.
- Winnebago_BobExplorerWhere we live the straight line winds are enough to make us drop the antenna and pull in the awning......
Only you can tell - think about the movement causing the base of the antenna to cause breaks in the sealant and you be the judge..
No brainer for me. - AllworthExplorer III have never thought of that as necessary and we have been in some doozies.
It it makes you feel better, it can't hurt anything. Watch a DVD movie.
About RV Newbies
