schl44's avatar
schl44
sewer hook ups
We are going to stay in a RV park in Colorado this fall. This will be our very first stay in a park. Our new camper came with a sewer hose. Im assuming all the conections are standard and it will fit. Would it be wise to get a longer one as I dont know how far I may need to go to hook up. Sorry for the stupid questions, but its our first time. Thanks for any help or pointers!!!
Lee
  • Once you get to the park, and see where the sewer connection is located, then you can pick up the system that will work for you. The Rhino system is a good one.
  • FYI do not leave your valves open keep them closed and then open them when your tanks get at least 1/2 full
  • I'd look up You Tube videos for things like that.
    Get a potable water hose. Use it only for sinking water.
    Get a coiled spray hose to rinse the sewer hose out.
    Pressure regulator for fresh water. Inline fresh water filter.
  • Hoses supplied with new RVs are often inferior. If that is the case with yours, you will never be sorry for upgrading your sewer kit. Get the Rhino Flex set up mentioned above.
  • ditto on the Rhinoflex system! almost always 15' is enough but you want to have another 10' add on section if needed.
  • Like most hoses supplied in the starter kits, if it does not have connectors on each end like this picture do yourself a favor and get one before you leave home.
  • I would suggest getting a Rhino Flex set up. They come in different sets. Many locales require a tight fit into the sewer system.
    Many Walmart have a standard 15 foot set. They are available on Amazon as well.
    You will be much happier not having to deal with sewer issues on the road.
    Rhino flex
  • Fittings are fairly standard (maybe). We have a 15 foot hose and an extra 10 footer as an extension if needed.
    Unless you are camping on the moon...sewer hose stuff is pretty much available everywhere if you find you don't have what you need.
    Some campgrounds (county ordinances)require that the hose be able to be sealed where it connects to the camp sewer pipe...
    Have a good trip. The sewer thing is all part of the adventure.
