Neracoal
Jul 07, 2013Explorer
sewer smell
i am new to rv's. the family and i took our first trip where we have used the bathroom toilet. Everything went well untill we left the site today. once we got under way to head for home the smel...
Fulltimers wrote:Closely related to the above situation is when you have an exhaust fan in the bathroom running and you turn it up high. When you flush, the fan is creating a pull as it pushes air out the top of the RV. Guess what sort of gas is going to replace the pushed out air as long as the toilet valve is left open. :)
What you experienced could be normal. If you had a window or vent open while going down the road, you will cause a vacuum, which will suck air down the tanks roof vent and inside the RV. It was probably actually the gray water tank, which can smell worse than the black tank. The vacuum can suck air up past the trap even though there is water in it. To cure this either close all windows and vents or get some of these tank vent covers or something similar. They really work!
