Effy
Jun 09, 2017Explorer II
troubledwaters wrote:Effy wrote:Really? What happens when you don't use any hot water for a while and the water in the tank falls below the low temperature set point? Do you drain all the hot water out and replace it so you only heat cold water?
My system must be different, I don't heat hot water. I only heat the cold water.
Really?
About RV Newbies
