wbwood
Dec 03, 2015Explorer
amandasgramma wrote:
Get a shower head that has a 'turn off" valve. I get in, wet myself down, click that button (water is off at the nozzle, not the valves) and soap up, then turn water on and rinse off. Two of us take showers in tandem, have never run out of water. I've even gone in to do dishes almost immediately after showering. :) :)
Ditto...learn to conserve water. Not only better for the environment, but makes things easier on you. Hot water will last. And less often that you will have to dump the gray tank.
About RV Newbies
