Sam_Spade
Dec 26, 2016Explorer
enblethen wrote:
Fuse for 50 amperes.
If that battery will be used to start an onboard generator, 50 amps might not be nearly enough. But then the main cable should be larger than 6 probably.
BUT.....why ? In most cases, the + cable to the fuse panel is fairly short and well insulated and isolated and should not really need a fuse.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
